Hi all, bought this for use under my TnD Loco but the Valve Gear on one side was US. So I have now split it up as bits. Parts are from a Bachman 4-6-0 Loco that had Plastic Valve Gear but Metal Wheels. Sorry no Tender available.
As usual PM me if interested in any of the items. May consider Sale as a Job Lot.
I have estimated Post with Royal Mail Second Class, if you wish for better let me know and I will revise Post Cost.
Lot 1
2 x Coupling Rods £3.00 Post 1.20.
Note Metal Bearings in good nick.
Lot 2
Front Bogie £5.00 Post 2.85
With Metal Wheels, this has been repaired and the Pivot hole is damaged so will need need some more repair. Or perhaps suitable to make a small Wagon with.
SOLD Lot 3
Left hand Plastic Valve Gear and Cylinder with Pistons £5.00 Post 2.85
Note Slider on other side broken.
SOLD 4 EDIT THIS IS OF COURSE THE RIGHT HAND SET BELOW!
Left hand Plastic Valve Gear £3.00 Post 2.85
No Slider on this side.
Lot 5
2 Air Cylinders £2.00 post £2.85
Lot 6
5 x Con Rod Spigots £1.50 post 1.20
Sorry lost one of these during dismantling if it appears before sale will be included,mbut it did ping to who knows where in the Workshop.
Lot 7
Basic Chassis £5.00 post 4.95
This has satisfactory Bearing Holes and sufficient screws to hold together, weight has been removed as securing Spigots broken, presumably in a fall. Would make a suitable Chassis replecement with revised Weight provision. Switch and Tender Connection at rear and Wheel Contacts included also Front Coupling assembly as seen.
SOLD Lot 8
Loco Body £5.00 Post 4.95
This has been weathered but otherwise pretty intact with Brass Bell and Light Bulb present. Would make a nice start for a Articulated Logging Loco as seen in here recently with 2 x Playmobil Motor Blocks.
Lot 9
Motor and Metal Wheels £25 post 4.95
Fully working Motor with Gears all in good condition, suitable as a replacement for a Trashed Motor.
I have had to estimate the postage as best I can, obviously if you Lot Up more than 1 item Postage will be revised downwards. I will pack up and give you a revised Post Cost.
Please PM me with Lot Number if interested in anything. I will be open to sensible offers.
PLEASE NOTE POSTAL COSTS FOR UK ONLY. ROW WOULD BE CONSIDERABLY MORE EXPENSIVE.
Lot 1
Lot 2
SOLD Lot 3
Lot 5
Lot 6
Lot 7
SOLD Lot 8
Lot 9
