WKDOR
Just attending to my much-loved but very elderly Croc.
It has been happily powered by R/C battery in a trailing Postwagen via the lighting socket (Shock Horror) for the last few years, but I'm now moving all the controls on board into the main engine room. One reason is to get a constant lighting circuit.
Using the several previous disassembly/chipping threads on GSM and here, progress so far is good - I've removed all the track pickups and worked out the existing wiring. Now for the lighting. My Enhanced RailBoss controller provides:
[*] a directional constant voltage lighting circuit at battery voltage = 18.6v.(excl overcharge), and[*] a directional constant voltage lighting circuit at LED voltage and current and I now need to decide which way to go!
I had considered redoing the lighting circuit in series. Using the existing old-style 5v bulbs (and leaving aside RhB lighting complications), I have 4 (3 headlights and one cab) lights at 5v per bulb = 20 volts in each direction. But that will require a complete re-wire of the circuit with lots of connections x 2.
I have also wondered about salvaging most of the existing circuit, keeping the existing parallel design but replacing the bulbs with Champex Linden/FGB 19v replacements that are LEDs in the same screw socket format with resistors. Has anyone used these?
Or I could rip all the lighting circuits out and start over with straight LEDs. Attractive, but a lot of work to shoe-horn eight LEDs in.
Help please - what would you do?
Mike
Mike
