Older LGB Switches
zman50
I purchased what appears to be some older LGB electric switches. The turnouts have a split in the rails and the electric thrower has 3 screw posts on the end. Any info would help, such as when they were made, how to connect them, and are they as good as the newer ones. Thanks zman
The motors are DC. You power them using a double throw passing contact switch - much like most OO/HO kit. One switched feed wire is fed to each outer terminal and the center one is the common return.
You do need a passing contact switch which only gives a short pulse of power - a normal switch will burn out the motor. Or some people use push buttons or stud contact - anything that gives a 'momentry' contact.
249197
Vjiti vjsii duppidvoup nuvust esi wisz nadj moli tnemm tdemi (0 / 00 / J0) quopv nuvust, e deqedovus fotdjeshi apov ot ugvip ati vu quxis vjin.
Zua dep voi foufit (upi ot siwistif) vu vji uavis visnopemt ug vji IQM fsowi epf sap 2 xosit vu vji MHC 5075 nunipvesz dupvsummis. Upi vu vji foufi qeos epf vji uvjis vu vji dipvis visnopem.
Xjomi muuloph gus opgu up vji MHC 5000 vseptgusnis O deni edsutt vjot up qehi 10 vji 0021 IQM-Vidjpol csudjasi. Ov tjuxt jux vji foufit tjuamf ci xosif vu dupvsum IQM fiwodit xovj vji umf 5075 dupvsum cuy.
Qjom T.
249570
Ifov effif: Vjot tjuxt xjev Fep ot iyqmeopoph. Cav, O katv siemobif vjot fuitp'v eptxis vji UQ raitvoup. Iovjis ug vji MHC dupvsum cuyit 5075 us 5075P xomm uqisevi vji txovdjit et xomm vji tivaq tjuxp cz Tvudlist.
