Once a happy flagman
railwayman198
A small lineside cameo that I have just about completed, mostly using bits that I had lying around.
The flagman is a Phoenix 16mm metal figure that I modified some years ago for my old indoor layout. I cut his arms off, drilled through his shoulders and bent up some brass wire so that he could wave his flag.
The motor is from a Piko gravel works building. The loading hopper kept on jamming so I took the motor out and used it to move the flagman`s arm instead. Way more powerful than required but it already has a flywheel cam fitted so it does the job.
The hut is from Pendlebury.
The plinth that holds the electrics is a plasticard box clad with natural stone from Richard Stacey. I bought a job lot cheap on ebay some months ago and used some of it on this project. The plinth is a bit bigger than I would have liked but I found that the motor needed to be located a couple of inches below the man to get a nice smooth arm movement. I can always say that the hut was raised to give better visibility  :D
The small hole in the plinth is to allow a screwdriver to access the cam fixing if it needs tightening
With the lid off
The last couple of pics show the mechanism. Inside the plinth are a the motor, 6xAA battery box, and an el cheapo remote control on/off switch (keyfob transmitter shown in last pic). The 6 AA`s give a nice realistic speed to the arm movement.
Very neat..
Like the idea of him being in the doorway, so the shadows hide the operating rod/wire.
Very neat and innovative... Once a happy flagman camped by a billabong, under the shade of a Coolabah tree.....
Neat idea!
I notice these receivers are designed to operated from 12v and you're using 9v. Have you discovered whether it still operates at 6v by any chance?
Rik
ge_rik said:
Neat idea!
Rik
I am using rechargeables at the moment which I think gives 7.2v. So I would think there is a good chance it would work with 6v.
Just tested the range. It works the full length of the garden, which is about 55 feet. Maybe it could do more but I don't fancy taking it out in the street :o
Excellent. I can see this working for the K&NWLR as well! :P
More Marvellous Modeling ! 8)
Another neat animation idea, filed away for a rainy day.
ROSS said:
I am not sure what frequency these units operate on, but I suspect it may be around 400 ...
Either 315 MHz or 433 MHz.
Effective, attractive and simple....excellent
