Hi Jon. Have you visited www.southernsteamtrains.com? There would appear to be some instructional articles there which might point you to a source.Could anyone point me to anywhere that has a pdf copy of the LGB/Aster Frank S (Live Steam) user manual, please?
I've been searching and can't find one, maybe my Google-Fu is weak today......
Many thanks in advance to anyone who can help!
Mike.
My pleasure. The trick was to find the LGB model number first then it was easy. I find a google search like "lgb <model> pdf" usually works e.g.Brilliant, Dave, that's it exactly.... I'd actually searched GBDB (or at least, I thought I had) and failed to find this...
Many thanks!
Your Google-Fu is strong today, Glasshopper.....
Owner/operator of a Frank S here, if you have any questions feel free to ask me. Just make sure you use only oil for live steam in the oiler for the cylinders. DO NOT use car motor oil. The original manual permited this, and this is death for the piston valves and cylinder piston rings. Distilled water only and butane or Isobutane for fuel. Tender water bath has to be filled with warm or room temp water to stablize gas pressure or Frankie cannot make enough steam to pull the skin off bread pudding. Post up some pics of your new engine. Anything Narrow Gauge had one for sale, didnt last long! Mike
lgb 2901 pdf
If there are multiple model numbers you can put them in a list in brackets:
lgb (2901, 2902) pdf
Same kind of search works with ebay as well.
