Pacific 231 by Occre
wrighizilla
Hello, I have built an Occre pacific 231 in 1/32 scale.
this model kit Locomotora Pacific 231. Modelismo ferroviario de OcCre. Ferromodelismo.
my model is dinamic with smoke and led lights.
I have done a lot of costruction build-log photo's here Pacific 231 — Postimages
motor unit is a 150 rpm JGY370 double shaft gear reduction find on ebay.
test video on my indoor railway
some outdoor photo's
WOW GREAT:clap:
Superb! Really interesting to see the photos of the kit going together. Really beautifully built and now you’ve got a glorious loco, congratulations!
a new Occre Pacific 231 video
I have tested locomotive pulling two Passengers coaches without any rubber traction rings.
the test is encouraging, I would like to modify the BR18, remove both motor units from the tender and also mount a 150rpm JGY370 reducer on that locomotive directly on the big wheels.
there would be many advantages, first of all I would no longer need a power connector between the tender and the locomotive, the tender would be very light, I could remove the rubber rings from the 4 small wheels which now give traction.
however, now putting my hand to an already built locomotive scares me a little, I cannot overturn it as I would like and I should take half of it apart.
I know where you're coming from, the thought of dismantling and messing around with a perfectly good engine doesn't appeal, I leave it for braver people
