Orgiva
My Pearse Ulysses has a problem. When pressure is building up in the boiler, I'm losing quite a bit of pressure through the filler cap's hole. The filler cap has a transparent plastic section over the bottom of it. Is this replaceable and do you think it's likely to be the cause of the loss of pressure?
