HI, I've acquired a couple of these from different sources and started to play about with them. I connected up the first and it switched over an old LGB 2-wire motor perfectly. 10 mins later I happed to touch the motor and it was hot. It transpires that the controller switches the polarity to the motor but doesn't switch off after the pre programmed time interval. Fiddling around with CVs, I found the values of 51 to 58 are all 67 (0.75 seconds pulse duration). So is there another place to tell the controller it needs a pulse and not continuous power?
Strangely, the 4th position works perfectly..... The second unit is identical so I suspect the common failure for these two is me.
Thanks
Nick
Thanks
Nick
