Am trying to pull one of these German Style 0-6-0 tanks apart. As you can see there are 2 screws that appear to be my final access to get the Boiler off to fit batteries and access the internal board.
These are only accessible via the chimney so far as I can see but the only screwdriver I have long enough does not reach due to having the plug in bit for the bit.
Oh light bulm moment, in my former IT kit was a screwdriver long ebough, but still stuck after unscrewing. So these not relavent either.
Have the breakdown diagram and it appears the key is the screw under the front footplate heading rearwards together with the screws inside the cab.
Finally came out with some j j jigling. So lots of additional screws taken out that did not need to be. There is a tab that was causing the problems!
Scews to rear of cab once cab taken off.
