I am having a problem trying to figure out how to hook up the LGB 51750 with the Piko electric switch machine. Being new at this hobby, everything is unknown to me, including the size of wire to use , where to get the power source , and which inputs and outputs are used in connecting to the LGB momentary switch.
As an example, I tried just connecting to the track where the power from the rheostat is located and it did not power the Piko electric switch. Perhaps my wire was too small? I was using size 16 wire. Also what is the amperage and voltage required to run the piko? The output of my Bachmann 5 (44217)is 1 amp, and when it goes in to the track I am sure it loses power and maybe not enough to power the switcher? Ok , I think you have enough information to hang me,,, lol. By the way, I only use about thirty feet of track so far, and am running a White Pass 108 diesel with sound and reverse. It runs very well and I cleaned the Brass track so every thing is clean. My joints are doing well . My switchers are being used to switch from a longer loop to a circle which is inside the longer loop. All is indoors.
I look forward to hearing a solution(-.-) Thank you all for being here, this site is a God send,,,
