SOLD: PIKO Track - points, crossings and curves - see below for prices
Sold for 90 GBP
All used but only indoors. Mostly boxed FWIW. None have rail joiners attached as I use rail clamps. I will supply the appropriate number of rail joiners with each piece if required. Please let me know if you want rail joiners when you order. You can have the whole lot for £90 or individual lots as below. P&P to UK mainland address will be £5 per order. Please PM me if interested. More exciting pictures of track below. I should point out that PIKO track is completely compatible with LGB track and just as sturdy.
POINTS
PIKO 35221 R1 right hand manual - boxed £15
PIKO 35220 R1 left hand manual - boxed £15
Note: the straight bit of PIKO points are 320 mm long unlike LGB which are 300 mm long
CROSSINGS
PIKO 35281 Level Crossing (European and US signs) - boxed £15
Note: the straight is 320 mm long.
PIKO 35240 30 degree crossing - boxed £20
Note: the PIKO crossing is symmetrical with two 320 mm straights, unlike the LGB 30 degree crossing which is "handed" and 300 mm long.
BUFFER £10 the lot
PIKO 35280 buffer x 5 (boxed) £2 each
CURVES £30 the lot
PIKO 35211 R1 30 degree x 20 £2 each
