Rhinochugger
Retired Oik
ROSS said:http://familygardentrains.com/primer/plants/knight/pot_in_pot/pot_in_pot.htm
Good advice.
Bonsai .............. effectively
Good advice.
I have actually practised this and it works quite well...ROSS said:Yep...I have advocated the method before.
Its ok as long as you trim the tops and the roots and bang 'em back in the pot..
Simple solution; depot the plant, cut a disk of BRONZE fly mesh ( bronze will repel the roots), if you dont have flys where you live then any fine mesh will do, put the mesh in the bottom of the pot then repot.trammayo said:Its a good idea! I kept mine in their pots, which has retarded growth, but the tap root goes down through the bottom of the pot and makes them difficult to extract :
Tramcar Trev said:Simple solution; depot the plant, cut a disk of BRONZE fly mesh ( bronze will repel the roots), if you dont have flys where you live then any fine mesh will do, put the mesh in the bottom of the pot then repot.
Ok so what do you call a fly that has no wings? A walk.....
Beddhist said:Do you think smaller holes in the pot would help against that?
Sorry, I niavely assumed no snakes - no flystrammayo said:Wot - no flys? With having a large area of wetland adjacent to us, flies are a nuisance (have a flyscreen at the backdoor), and so are the biting wee beasties
