POLA 331080 barn
Tony
Model railways
John i dont have the barn but i do have the wood shop and the roof and walls look identical as do the eve panels above the doors but mine is open both ends so cant give you door openings etc if you want i can post a picture and measure the roof area etc hope this helps
The wooden cross pieces are mine to mount the lighting
J2s said:
It looks exactly the same Tony. Thanks for your reply.
All I need is
1) the width of the door hole . 16.5cm
2) the height of the door hole from the floor of the workshop. 12.5cm
3) the height of the masonary that it is standing on. 5cm
I would be much oblidged. Thanks. :) A few other measurements just in case are side walls to roof 15cm high and the walls floor plan is 30.1 x 38.5
my pleasure
