tramcar trev
Just thought I'd run this by the forum......
I was trying to think of a way of taking power of the figure 8 x 2mm wire that I'm running under the tramway to supply power for lights, buildings etc...
I came up with this; drive a brass or stainless brad through the appropriate conductor, then wrap the wire to the load around the pin, dob of solderpaste and touch with an iron. Coat the joint with some liquid tape.....
Would save having to hold wires while they are soldered and cutting and joining the main supply... Is there another simpler way?
I have upped the operating voltage for the traction side of things to 13.25VDC because I measured out 20 metres of the brass wire I'm going to use for the overhead and measured the resistance then using an online calculator worked out that 13.25volts would allow me to run without having to have too many feeders.... It was easy to do, there is a trimpot on the power supply that lets one adjust the voltage....
