Sjoerd1985
I have a circle railway with a track length of about 20 meters in my backyard. For the power supply, I buried speaker-wire (this stuff: https://www.allekabels.nl/luidspreker-kabel/4479/1302342/luidspreker-kabel-op-rol.html) along the track, which is connected to the track at six locations.
In the winter of 2023-2024 the connections to the track all broke , probably as a result of freezing temperatures. Last year (2024) I didn't restore it, as I only used remote controlled battery powered trains (Playmobil 4010, 4011, and a Newquida Steam locomotive) on the outside track.
Now that we are starting to get warmer weather, I just tried to strip of the end insulation on the ends of the wires in order to re-connect them to the tracks; I want to use the line with track power again, so more models can run outside (LGB/Piko/USA Trains).
However, every time I tried to strip off the insulation on the end, that end of the cable just broke off immediately (both insulation and the core wire). So... complete power cable replacement seems to be needed, but this time I want something more durable.
So my question is; what kind of cable do you use, which can be used multiple years without having to be replaced?
