Current setup:
I have an old LGB 50110 18V AC transformer. The LGB control station died but the transformer still works. Do I just put that somewhere convenient and run the lighting circuit directly from it?
Thanks
- Control station is a Roco z21 XL, which delivers 20V DCC power. Also have a z21 XL booster which is not currently wired in but will be eventually
- 3 LGB locos with after-market DCC decoders
- around 100m of track. Several turnouts - DCC control for the turnouts is mainly via the track. No seperate accessory bus, just tap off the main bus or track to run to stationary decoders where appropriate.
- LGB decoupler lanterns
- LGB buffer stop lanterns
- Connect directly to track. I'm concerned about the side effects of this, both on current draw via the track and possibility of burning out the bulbs.
- Run a separate 18V lighting circuit. AC or DC?
Thanks
