Geoff the garden nav
Aristocraft locos & rolling stock, mid C20th to co
I recently wondered why one of my U25b's was stalling / faltering on points, its been quite a hard winter, the track could be cleaner and probably the wheels. Back indoors with the loco carefully turned upside down I did a test with power directly onto the the wheels to see if all the wheels were picking up power. Sure enough one set of wheels per motor block were dead. Opening up the motor block reveled that the one of the thin copper wires from the axle without the universal joint, had fused, burned out presumably due to a short circuit, resulting from a derailment? checking two other later U25bs and a nearly new RS3, each had an axle with a similar problem. I have cleaned up the copper wires, stretched it out a little from the abrupt 90 degree bend near to the screw terminal and silver soldered the ends back together with an overlap, so far so good. A continuity test with multi meter between pairs of wheels on the same side of the motor block quickly reveals the problem. Is this common? I use an Aristo train engineer in pulse width mode with a 10 amp Crest power supply, presumably this is the result of short circuits which didn't blow the inline fuse! and damage which went un noticed at the time, is this a well known problem with this type of motor block? something to watch out for.
