Question about steam locomotive technology
Andreas
What is the marked device? Some locomotives have one or two, some don't.
Thanks for your help
Bildschirmfoto vom 2021-03-06 13-02-58.pngBildschirmfoto vom 2021-03-06 13-05-10.pngBildschirmfoto vom 2021-03-06 13-06-19.png
Yep, that's what they are.
A jack (like to lift a car to change the wheel) but bigger and heavier..
Used to help re-rail the engine or stock.
Usually a sign of poorly maintained track.
hi thank you
I hadn't thought of that. I learned something new again.
Hello together,
I need help again.... What are the two boxes on the front right and left of the locomotive?
in-moyasta-ein-streckenabschnitt-west-997130.jpgslieve callan.PNGschmal_wcr_irland_10.jpg
thanks in advance
Hard to tell: it looks to have a filler on the top, so may well be a sandbox -it is certainly big enough, but they are often positioned so the sand is fed just in front/behind the driving wheels. It looks too big to be an oil reservoir, and the small circular lid suggests it probably isn't a toolbox.
The previous item is a traversing jack: they have a vertical thread for lifting the locomotive, and a second one to move it sideways, back onto the track. As others note, they often appear where track is poor.
Also used for doing on track repairs to the loco... handy when stripping down valve gear etc that needs removing. Also good when you have to jack and pack a wheelset up so it don't contact the rail.
Wot? Yes, when a bearing/axlebox seizes up and the wheelset will no longer rotate, you 'take down ' the valve gear, jack up the crook wheels, pack under the bottom keeper to get the wheels clear of the rail, then drag the miscriant home on the remaining wheels. Idea don't work too well on 0-4-0 locos though.
Hi all,
Northsider is correct, they are sandboxes. The ones on Slieve Callan are dummies, we don't have a need for sanding for hauling our two carriages on our relatively level run.
Regards,
Eoin
