Rhinochugger
Retired Oik
I now have a working chassis for the VW Combi Drasine/Speeder (I'll post a picture in the Scratchbuilding section as soon as I've taken one 8| )
I'm intending to use battery power, without any speed control because there isn't a lot of room.
I'm using a 6v motor (from an early Bachmann bug mauler) and have tested the gearbox with two AA cells giving 2.4v. This seems to provide an adequate speed at the axle taking into account the wheel diameter.
However, my intelligent charge will only recocgnise a minimum of 4.8v, and if I use four cells, I'm concerned that the speed will increase.
How can I keep the speed down?
I thought about using two DPST switches instead of a single DPDT to swithc between charging and running. by doing that, I could charge 2 x 2.4 cells in series and run them in parallel :thinking: (NiMh 2100 mAh)
I'd need two in line fuses, but that'll take up less space than a speed controller, and even if I could install a speed controller, there'd be no way of operating it, as I don't want to go to the expense of R/C (I'm supposed to be building this on a budget
