gscalerookie
Looking at the reversing loop in the Lgb manual it calls for 11-11000 r1 curves, but i want r3 curves at least. How many 16000 r3 curved sections would i need to make a reverse loop?
... plus one of these short (7cm/3") adapter pieces to make the "R3" turnout reach the full length of a R3 curve.you will need 15 x R3 curves plus a 16?0 turnout and some straight track..
Ok after staring at it I figured 12 for a full r1 circle minus one for the turnout. 16 for a fullr3 circle minus 1 for turnout leaves 15There are 16 x 22.5 degree track sections in an R3 circle, so you will need 15 x R3 curves plus a 16?0 turnout and some straight track..
You could also use 11 R3 curves, a R3 turnout and 2 x 10000 straight track pieces (or equivalent) to give you a 'tear-drop' loop.
You then eliminate the S curve and the loop can be used for longer trains.
I had to lengthen my reverse loops to fit in my 7 car TEE set, which has pickups on each power car at each end of the consist....
Oh so I can use 11 as described in the manual just swap the curves and turnouts and add a few straight to mate up to the turnoutYou could also use 11 R3 curves, a R3 turnout and 2 x 10000 straight track pieces (or equivalent) to give you a 'tear-drop' loop.
Yes, a long straight off both roads of the turnout to your slightly more than a half circle will give you a long return loop....Oh so I can use 11 as described in the manual just swap the curves and turnouts and add a few straight to mate up to the turnout
ThanksYes, a long straight off both roads of the turnout to your slightly more than a half circle will give you a long return loop....
You might take a look at some track planning software, such as Anyrail (www.anyrail.com) It's free for up to 50 sections of track which would be enough to plan your reverse loop. There are others, and many have their favorites, but I find Anyrail is a great way toThanks
I did download the software last night I was just trying to place a quick orderYou might take a look at some track planning software, such as Anyrail (www.anyrail.com) It's free for up to 50 sections of track which would be enough to plan your reverse loop. There are others, and many have their favorites, but I find Anyrail is a great way todreamseriously plan. It lets you try various arrangements until you find something that will (theoretically) fit. And, it's really pretty easy to use.
This is my goal. I currently have a switch kat controlling the turnout with the nce power cab. Do you think I can make this work with the current setup or do I need to wire something else.Yes, a long straight off both roads of the turnout to your slightly more than a half circle will give you a long return loop....
I'm not familiar with the switch cat. Does it have a switch that can reverse the polarity?This is my goal. I currently have a switch kat controlling the turnout with the nce power cab. Do you think I can make this work with the current setup or do I need to wire something else.
I have a lgb supplementary switch I could add to the electric switch like pictured. The nce switch kat decoder takes track power in and two wires exit to the turnout motor to control itI'm not familiar with the switch cat. Does it have a switch that can reverse the polarity?
Otherwise you will need a DPDT switch....
Switch katI have a lgb supplementary switch I could add to the electric switch like pictured. The nce switch kat decoder takes track power in and two wires exit to the turnout motor to control it
Yes dccAs you are using DCC, I would use the LGB 55080 reversing loop units or something similar, to change the polarity.
They are what I've used....
