gregh
Way back in 2010, I built a small 0-6-0 loco for my grand-daughter, Lexie. As she was only 3 at the time I used a simple forward/off/reverse switch on the boiler.
I described the construction of the loco in this post:
https://www.gscalecentral.net/kit-building-bashing-scratch-build/a-small-0-6-0-tank-on-a-piko-motor/15/#lastPost
Now she’s older, I reckoned it was time to ‘RC’ it.
I used my ‘standard’ Hobbyking (aero modeler) 2.4GHz equipment, utilizing an existing transmitter.
For more info on how I use Hobbyking RC stuff, see my web site here: http://www.members.optusnet.com.au/satr/2point4GHz.htm
So all I needed was the batteries, a Receiver, an ESC (speed controller) and my standard method of reversing direction.
I used six, AA size, NiMH LS type batteries (It had 4 cells already). I just soldered them together in series and put in the side tanks. I used only 6 cells to keep the speed down, since kids seem to have only one speed when controlling – MAX. Top speed is about 45 kph.
For reversing I use a DPDT switch glued to a servo with a cam to operated the switch.
I hot-glued the 3 main bits together, soldered to the battery via a 3.7A polyswitch and switch, plugged the servo in channel 1 and the ESC in channel 3, connected to the motor via a 2-pin plug, and stuffed them in the boiler.
And that’s all it takes to add RC ! Getting the cam the right shape took the longest.
Total cost around 50AUD. (25 GBP)
SOUND
The loco already had a simple sound system, using a Picaxe which just had a constant chuff rate (the manual loco had one speed!). So I modified the circuit to provide a ‘speed voltage’ input from the motor, and wrote a new program.. This is the simplest possible circuit I’ve made. There’s no volume control as I usually use, and no amplifier. The speaker is just driven by a small transistor. It does a soft hissing when stopped and a louder chuffing when running, produced by the white noise generator in the Picaxe. I didn’t try very hard to get the chuff rate correct to wheel speed, but it’s good enough for an 8 year old.
There’s a short video to show off the sound…
[size=12pt]http://youtu.be/HngE_ebezik[/size]
And finally I had a hole in the boiler top where the on/off switch used to be, that needed filling. As much as I dislike bells on trains, I figured Lexie would like it and it was easy to add. So it’s got a bell, gasp, shock, horror!
SOUND
