Madman
I dismantled a 2017 tender motor. The two halves of the clamshell gearbox separated nicely. However, I cannot get them to go back together. I am meeting resistance from one of the motor tabs, and if I force the shell on it bends the tab. The motor is properly in place. There is a small tit on the end of the motor that sits in a groove. That aligns OK. The thrust bearings are in place and the worm gears are seating properly.
I've looked at the brass bar on the other side and the motor tab is resting nicely against it. It doesn't look any different than the side I am trying to get back on.
