As you know i'm not an alchemist so not best placed to give tech advice...8| we used to use a 12v car battery charger and Nickle welding rods (we were poor) to plate engine detailing parts the thickness depends on the length of time you leave it going but best off doing it two or three times times for short periods (no more than 5 minutes) to build it up but i will say prep and cleanliness is everything and if you want a shine on something you will end up polishing your life away...all i know is the being able to do it is not as hard as you would think and you dont need fancy equipment ...............one thought tho the original plating cant be that good cos it doesn't last so you must be able to do betterbeavercreek said:Looks good Tony
Just still wondering how thick the plating will come out and therefore how long it will last especially on loco drive wheels.
