Phoenix do just the thing. Their products are excellent but pricey.
http://www.phoenixsound.com/library/am_steam.html
http://www.phoenixsound.com/pdf/3Shay.pdf
Personally I'm very happy with the mylocosound chip. The important thing with a Shay is that it should be chuffing like mad at a low speed.
The card in my Shay is a few years old and not so sophisticated as the currebt ones. It was one of the first fitted with chuff shut off when voltage is lowered. But it does the job for me. I do have a couple of the latest ones and they do do more tricks.Love the video Chris.
MyLocoSound at £49 or A$89 will give the correct Shay sounds. Using a TV remote control, the chuff is adjustable to match the loco and is synchronised to the motor voltage and load. There is a good video of MyLocoSound in a Bachmann two truck Shay at. The radio control used by Peter Spoerer is virtually identical to that used by Tony Walsham at RCS. Tony also sells lots of MyLocoSound, for both radio control and track power, and can give you good advice. MyLocoSound is not compatible with DCC.
The MyLocoSound whistle is adjustable in style, pitch and volume. You can trigger it, plus the bell, safety valve and "All aboard", manually using transmitter buttons on radio control.
On track power, the normal choice is to use the automatic sound modes. This causes the Westinghouse brake pump to sound automatically each time the loco is stationary. It also causes the bell to ring when the loco is moving below a user selected speed or when triggered by magnets under the track. The whistle can also be triggered by track magnets or by the remote control. It conforms to US whistle codes when starting and stopping and can sound the grade crossing sequence when triggered whilst in motion. A slight nudge on your speed controller will cause the safety valve to blow.
You can contact Tony Walsham at RCS or email me at sales@mylocosound.com if you have any questions.
Regards
Peter Lucas
MyLocoSound
Peter, I managed to get the Westinghouse pump to sound when I had the loco static on the bench, but since running it on the track I've not been able to find that mode.Love the video Chris.
Regards
Peter Lucas
MyLocoSound
Peter, many thanks, I will have another playWe recently changed the way the Westinghouse brake pump worked. Previously operation was entirely manual. You pressed the 5 button on the remote control or function 5 on the radio control to start and stop the brake pump. Recent versions of the soundcard work differently. Pressing the 5 button on the remote control now switches the automatic brake pump on and off. When switched on, the pump runs automatically each time the loco is stationary. However you can still use manual operation if you prefer.
If your brake pump is not sounding when it should, you may have accidentally turned its volume right down. I suggest that you reset the soundcard by holding down button 3 and then switch the brake pump back on using button 5.
Regards
Peter Lucas
MyLocoSound
OK, have sorted the Westinghouse pump - thank you PeterWe recently changed the way the Westinghouse brake pump worked. Previously operation was entirely manual. You pressed the 5 button on the remote control or function 5 on the radio control to start and stop the brake pump. Recent versions of the soundcard work differently. Pressing the 5 button on the remote control now switches the automatic brake pump on and off. When switched on, the pump runs automatically each time the loco is stationary. However you can still use manual operation if you prefer.
Regards
Peter Lucas
MyLocoSound
Oh for a sound system that could replicate a "quillable" whistle.
Just like on that video.
