Re:Regner lumber jack and a tape measure
Many thanks for all your help.
I?m building a gauge 3 tank engine and need a power unit. GRS sell some geared ones, and I?ve head good and bad things. I?ve asked Regner if they will supply their unit and gears as a spare and am waiting to hear back. I feel this will be a better option, and now think they will fit in between the frames- its an inside frames engine that I?m building.
Failing that I may use mamod upgrade type cylinders and meccarno gears. However to do this I will need the reversing block to have about 4mm milled off each side and the same done to some spacers, something I can?t do.
Much as I?d love proper cylinders I can?t make the motion up, and it would cost the earth.
By the way, this is why I was after the Edrig parts.
