artfull dodger
Dealing with a burner issue on my new Regner Stainz. If the smokebox door is closed, the flame does not want to stay on the burner but instead wants to burn about 3/4 of the way up the burner tube where the cross tubes are. Does not matter if the exhaust pipe is up the chimney or not. I tried an air control ring on the air intake side of the burner, that did not help either. The smokebox bottom is completely open, and even the smoke box support on each side is a grate instead of being solid, so plenty of air getting in there and places for the exhaust gases to go be it up/down/sideways! Is she over jetted? I tried swapping with my Konrad, which is very stable(almost Roundhouse stable even) with its burner performance. But that yielded no change on the Stainz. She ran well otherwise as long as the smoke box door is open like 1/16th of an inch. I want to light the front lantern so I need that door shut to protect the bulb and wiring. It also looks odd running with the door ajar. Open to other ideas to try. Next steam up is in late January, so I have some time to work on her. Would wrapping the burner with stainless mesh help? Smaller gas jet?(no clue as to the stock size in it now and Regner uses a much smaller thread diameter than RH or Accucraft). I love the engine, just uncertain which waya to go forward to solve this burner performance issue. Thanks Mike
