viaEstrecha
Until now, I've managed to avoid having to mess about with the drive train on any of my locos. Unfortunately, I need to replace the reducing gears in my imported second hand LGB Corpet-Louvet (LGB 21780), they having stripped when it derailed in a hidden part of the line but somehow managed to keep running for several minutes. I have obtained the replacement set of gears (LGB part E133761).
I haven't a clue where to start. I can see from the exploded diagram how to access the wheelset, but am scared stiff of a. disengaging the coupling rod (is it held on with some push-on/pull-off pin shaped like a hexagonal nut? Do I use pliers or is it actually threaded?) and b. subsequently taking a wheel off the axle in order to fit the new gears (does the axle tap simply out of the wheel with a punch?).
Anyone have any helpful hints or tips to give me some confidence, please?
