trammayo
The above loco was the first to receive a replacement chassis (Taming a BH). There was nothing wrong with the drive mechanism - sweet as a nut - but rather the pony truck swivel arrangement. The original chassis was laid aside (along with another replacement until I had time to work on the two locos needing attention!
Well anyway, yeasterday was the time.
My Santa Fe BH (an earlier Big Hauler) was quite noisy on the gear side of things. As the chassis from the first loco had red wheels (same as the SF) I chose to use it as the relacement.
Here is the chassis I wanted to use as replacement....
... and the one I wanted to replace ...
pics of both opened up - different motor mounts and gearing arrangements ...
(Note dry gears!)
... and the newer version of the BH chassis...
I didn't want the swivel arm pony truck but, as the mounting was part of the arrangement something needed to alter. Also, on the newer version the axles had proper brass bearings, whilst the original had none. (both methods seen in above pics). The cover plates also show (or don't) the pick-up contacts. In the original, the pick-up were direct from the backs of the wheels.....
The differences as quite obvious. The arced slot for the pony truck swivel, whilst not the best arrangement, is what I prefer for running on the R1s of my trailer set up. The square block with four tiny black CS screws is (or was) the mounting for the truck.
More to follow...
