Dinas Bryn
Morning all is there a MTS sound unit for a Kroc? Les
muns said:Hi Les,
Massoth have sounds for the Crok so you would have to install a XLS decoder or add a S sound module (if you can get one).
That code doesn't exist on the Massoth XLS list, 8230042 is the modern Ge4/4 III which sounds nothing like the Krok.Dinas Bryn said:Thanks for the infro I have just looked at Glendale, P&S and Dragon no 8260042 so were is it sold? Les
PaulRhB said:That code doesn't exist on the Massoth XLS list, 8230042 is the modern Ge4/4 III which sounds nothing like the Krok.
With the XLS decoders you have to select the decoder as an item then they usually have a box to type in the code which tells them which sound to upload. I'd suggest ringing to make sure they know which loco it is if the sites are confusing.
