Roundhouse Criccieth Castle Horn
ChessieRR
I have a Roundhouse Criccieth Castle and when I pull the trigger it does not sound its horn. It seemed from the instructions that that was one of the features of the sound system. Can someone verify if that is correct, or if there is a known issue with the horn sound?
Thank you.
-Adam
Hi Adam, yes if you have the sound system fitted pulling the trigger should activate the horn. Not sure what's happened there, maybe the trimming switch on the remote has been moved? or try pushing the trigger the other way as one of the reverse switches might have moved.
Ross
If this is a standard fittment from Roundhouse would it not be an idea to contact them direct. If there was a known issue they would be able to advise you. Very helpfull bunch from my experience.
Max.
