Hi Peter,
We are very pleased indeed with our new Roundhouse Engineering Darjeeling Class D Garratt which has performed faultlessly since she arrived two weeks ago.
She has behaved perfectly every time we have run her and we would recommended her highly to anyone who is thinking of making a purchase.
We understand that over 100 locos have been ordered since she was launched in April 2015. She fits in really well with our other Roundhouse locos and is very similar to run with her 2.4.GHz radio control for speed and direction.
She has a water top-up system which allows for almost continuous running. We have found it best to run her for between 10 to 15 minutes and then top her up with water and gas. She only seems to need a top up of steam oil after about 20 to 30 minutes.
She runs very smoothly and negotiates our up and down railway with great aplomb.
Amazingly, she's almost silent when the two gas burners are turned down but still produces enough steam to pull a very heavy load.
She has a copper boiler with a volume of 286 ml working to a maximum pressure of 2.6 bar or 40psi. The safety value is set to release at 2.6 bar or 40 psi as well.
The copper and brass gas tank has a test pressure of 33.3 bar or 500 psi with total volume of 45 ml. The maximum working temperature is 60 degrees C with a maximum working pressure of 16.7 bar or 250psi.
Her boiler is approximately 19 cms long and has a diameter of 5cms. It was somewhat difficult to get an exact measurement as there are lots of pipes under there!
Hope this helps.
Best wishes from the Pine Tree Junction Engine Shed!
