I have an older analog Arosa Locomotive from LGB, and I have some questions about running it off overhead power.
I know there's a selector switch inside the cab, but when you wire up the power pack, does it matter which wire goes to a rail and which goes to the overhead catenary? I only have 1 throttle, and and I use an spot switch to select tracks.
Also, I saw some white dots on the truck frames, next to the wheels. They are only on one side. Do these have anything to do with how you have to connect power?
Thanks
Thanks
