Hi Guys
Can you help me out. I bought a new Accucraft Countess which was steamed four times and on the four time the servo failed on the regulator. It worked prior to steaming then would not operate the regulator when steam was raised. The loco has gone back to Accucraft, servo replaced and all working fine until steam was raised and again the servo has failed and not working. Has anyone else had this problem?
I am considering taking the engine apart and replacing the servo with a bigger more powerfull one, any tips on taking the engine apart, ie is it just a case of undoing all of the small screws that you see underneath the side tanks to remove the cab etc.
Mechanically I am fine but my colleage is a wizz on radio control so he is going to test the servo and look at fitting a larger one.
Any comments re your experiences would be welcomed.
Thanks
Steve
Thanks
Steve
