Ask that well-known benefactor Robin BanksHmmm! Now where can I acquire some pecuniary assets?![]()
Ask that well-known benefactor Robin Banks![]()
That was exactly where I was going Tony, thanks. A simple change of axle set. That will of course slightly restrict it's turning radius but not enough to bother me with 4ft min.
No need to change the axle, just the wheels. 4 foot radius might be a challenge though.A simple change of axle set.
Just out of curiosity - why would you want flanges on the center drivers?
Yes, I have a Lady Anne with 6 flanged wheels. End float is the answer and I achieved this by filing a small amount of the centre axle's bearing thrust faces, so allowing the centre axle to float by a small amount from side-to-side. I have 4ft 6in radius points on my line and they do not present a problem, but I have nothing of smaller radius to try it on.Tony, do you have experience with a six wheel convert? as long as there is a bit of axle end-float I'd have thought it would manage reasonable radius'.
The wheels on the blind axle are actually smaller diameter so don't touch the railhead, meaning that effectively it is only a four wheel loco.
I assumed, not always a good idea, as both my Countess (Accu I know) and my L&M have smaller wheels. It seems to be common practice.
Thanks for that info, as that probably means hat the extra flanges may not be needed. after all.
Manufacturing tolerances . . . . . . .![]()
Or would that be Chinese QC??
I used to think that flanged wheels looked better than blind ones - but when you see them on such iconic full sized locos as the 9F's and the P2's - they don't look so bad ....![]()
