Casey's mate
Been running my Roundhouse Silver Lady today and I've had a few problems with the Radio Control. When the engine was cold, everything worked fine (Always test at the start of a running day). Like normal, I light the engine, get up steam, take it up the shed road with the drain cocks open clearing the cylinders, then couple to the coaches and run. However after about half a lap, I decided to switch the steam from chimney to rockets and I lost control of the engine.
So I stopped the engine, switched it all off and left it for about 5 minutes. Then it worked again! I thought I'd re light it and then not touch the rockets...it runs and I have complete control. As soon as I switch the steam from chimney to rockets, no control again. Tried this a couple of time and it happens again and again. Sometimes it will continue to travel in the same direction at the same speed, sometimes it stops, others it shoots off into reverse.
Tested the batteries, 5.2 volts - Tested my Russell's batteries and that also had 5.2 volts. Anyway I changed the batteries and got 6.2 volts and some problem. I've not taken the loco apart yet, has anyone got any ideas, suggestions, experience, advice as to the problem and how to sort it?
Scott.
(Engine info: Built May 2009, originally fitted with space gun 40MgH controller but sent back to Roundhouse October 2009 due to problems with that and was fitted with an E-sky 2.4 - never had a problem with it until now)
Scott.
