a98087
Hi allow recently done a very quick and simple manual battery conversion, so I thought I'd stick up a picture and a few words to show how simple manually controlled locos can be
The loco concerned is a playmobil express, I had previously swapped the 4 X AA powered motor block to a 12v block, this makes no difference apart from the required battery voltage.
The speed controller is sold on eBay as a
DC PWM 3-24 motor controller
There's a selection so just choose one that suits your chosen battery voltage
All I had to do was the following
Connect the battery and fuse
Use a DPDT switch to control polarity
Make up a little stand/control mount
Connect the output from the switch to the motor terminals
Remove track pick ups
The total cost is about £10 plus battery,
And the end result is a train that you just set the speed and leave to trundle round
The electrics and battery don't take up much room so can be easily fitted to most locos, I had originally fitted this set up to a lgb u class and it all squeezed into the cab,
And now two pictures of the testing,
Any questions just ask
Dan
Dan
