These are signals suitable for German (and in some cases Austrian) narrow gauge railways.
They are all designed for outdoor and indoor use, mostly brass and some plastic components. All will run off 12-24v DC and all have LED protection resistors fitted. The signal with the flashing light has the logic built in. They are all in good condition and have only been used indoors. I have reviewed these signals on this forum to provide more information and pictures:
Review of GSSB IIm scale light signals
DIETZ WL-KS switch signal
The signals are:
Hp0/Hp1 Block signal red/green lights (two of these for sale)
Bü1 Crossing signal (Bahnübergange) flashing white light
So18a/b Sprung point signal two white lights
Wn1/Wn2 Point signal (Weichen) three white lights
See www.sh1.org for information on how these signals are used, specifically:
Block Hp0/Hp1 Hp system
Bü1 Level Crossing Signals
So18a/b Point Signals
Wn1/Wn2 Point Signals
The Wn1/Wn2 signal includes an LGB point auxiliary switch (12070) which you can use to set the signal lights accordingly.
I have tested them all. Pictures below.
There is no website for GSSB, as fas as I can tell it is a "one man band" who builds signals to order from grootspoor:
You can see the complete GSSB range including these here: Search results for: 'gssb' | grootspoor.com
The DIETZ website is here: WL-LED
I would estimate P&P to be £3 for one signal for UK mainland address. I would prefer to sell the lot in one go in which case you get one free.
PM me if interested.
The signals are:
