I'm having a clear-out, and first to go is all the Massoth stuff I have accumulated over the years which is no longer needed.
ALL GONE!
All items listed are working AFAIK and complete with manuals except where noted. I've give the part number, so you can look them up on massoth.de if you need more details, even for the discontinued items. P&P to UK mainland £4 for one or many items.
Fire Box Light 8242060 x 2 (one missing reflective shield) £4 each or both for £6
Potentiometer (volume control) 8242010 £2
Function Decoder (discontinued) 8152001 £8
Visaton K57FL 57 mm flat loudspeaker 2 W 8 ohm 8241021 £4
Powercap Micro (stay-alive capacitors) 8151601 x 2 £6 each or both for £10
Pulsed Smoke Generator (square, digital) 8413501 £20
Cylinder Steam Module 8413901 (included)
(Steam) Tube Set 8412901 (included)
Automatic Uncoupler (old style, one only, don't ask!) 8424002 £10
Accessory Decoder 1 Channel 8156601 £10
Accessory Decoder 4 Channel (painted black!) 8156001 £15
Accessory Decoder 4 Channel (only first two ports work!) £10
DiMAX PC Module (plus mains power pack) 8175101 £30
Note: the power pack is an old HP laptop power pack providing 19.5 V DC which will power the PC module. The CD included in the box is more or less useless as it is very out of date. You have to download the data required for the PC module to work from an FTP site that Massoth provide access to. I have to admit I don't know how that works when you buy a PC module second hand, but I assume there is some way of doing it.
The following Massoth related cables are free to the first claimant (plus UK mainland P&P of £4 for one of many items). These are all shown together in the last picture.
SUSI 4 pin mini-CT at both ends
eMOTION DCC Interface Cable p/n 8312062 (LGB 10-pin)
10-pin blanking plugs x 2 (revert LGB 10-pin interface to DC)
eMOTION PCB and Decoder brackets p/n 8104010
3 pin mini-CT to individual wires
4 pin mini-CT to individual wires
track and power cables (brown white green yellow) x 8 sets
Plug-in Light Bulb 5 V p/n 8311110 (only 6 remaining from pack of 10)
![20230630_114927.jpg 20230630_114927.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485339_20230630_114927.jpg)
![20230630_115007.jpg 20230630_115007.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485340_20230630_115007.jpg)
![20230630_115048.jpg 20230630_115048.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485341_20230630_115048.jpg)
![20230630_115242.jpg 20230630_115242.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485343_20230630_115242.jpg)
![20230630_115322.jpg 20230630_115322.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485344_20230630_115322.jpg)
![20230630_115518.jpg 20230630_115518.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485352_20230630_115518.jpg)
![20230630_115656.jpg 20230630_115656.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485353_20230630_115656.jpg)
![20230630_115835.jpg 20230630_115835.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485354_20230630_115835.jpg)
![20230630_115929.jpg 20230630_115929.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485355_20230630_115929.jpg)
![20230630_120100.jpg 20230630_120100.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485356_20230630_120100.jpg)
![20230630_120135.jpg 20230630_120135.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485357_20230630_120135.jpg)
![20230630_114632.jpg 20230630_114632.jpg](https://cdn.gscalecentral.net/2023/06/thumb/485360_20230630_114632.jpg)
ALL GONE!
