Used but still fully functional, in original box with instructions and some notes from me on "extra sounds" not documented by PIKO.
This is a SUSI sound module so you need a decoder with a SUSI interface such as Massoth L or XL or PIKO equivalents.
It comes with Visaton FRS 5 8 ohm speaker attached so no soldering required.
You can connect it to a wheel sensor (not supplied) but that would need some fine soldering skills.
To program/configure it you need a DCC system capable of writing/reading CVs in the 900-1000 range.
It is not currently set to factory settings as I assume you will want to change them anyway, but let me know if you want me to reset.
These are still available new at £124 (topslots'n'trains price) or thereabouts.
