Greg Elmassian
Guest
There are some changes / improvements in the Revolution Train Engineer equipment.
I'll be adding these bits of information as I go, but thought I'd share it here until all the web sites and dealer sites get updated.
First the new super receivers have 3 terminals on the output. The label shows that you use the outer 2 terminals. The center terminal is not used at this time, and it is for future expansion. No information on what what will or may be.
Note that there are 3 output terminals on both super receivers. The center terminal is not used, and is for some future expansion, as of yet unannounced.
The current capability on the PWC unit is 15 amps, and 10 amps on the linear unit.
At max current, a fan is recommended.
You will also note that there is no external fuse, it is now internal, and the overcurrent circuitry has been beefed up, so the external fuse is not needed.
The inputs are polarity sensitive as before, and never connect power to the outputs.
The 50791 PWC to Linear converter has also been updated to 3 terminals, but for now you also only use the outer 2 terminals on the input.
Hope this helps.
Hope this helps.
