Can be advantageous to use Butane/Propane 70/30 mix for easier lighting up etc.Charles M said:Butane doesn't like cold weather
I use 30/70 propane / butane mix and have never had any problems. It makes a big difference when its cold. Just make sure you don't buy pure propane by mistake as the bottles look similar. The lowest percentage should always be the propane.stevedenver said:so, NHN, and others with first hand experience only- no issues with using the 70/30 propane butane mixture eh-???
is this the very same stuff from teh camping stores-with the threaded collars??
i had heard that propane has a higher pressure
but -i think this could make a huge difference--i am sure it would with my SRRL , and
very likey the frank s -even the tender water bath for the tank is a royal PITA when it gets really cold
and -i use a thermos and microwave my distilled water in a large pyrex measuring cup for refills-makes a huge difference-and -a good thermos will keep the water very hot a very long time
None whatever, in the UK, any season, any make of loco:- Maxwell Hemmens - Accucraft - Roundhouse.stevedenver said:no issues with using the 70/30 propane butane mixture eh-???
Agree with Rob's post here but with a proviso. I would NOT use mixed gas in Merlin locomotives, Archangel locos or indeed early Roundhouse in summer weather. I have seen a Merlin tank 'bulging' because the owner used mixed gas. Modern locos are fine.MRail said:None whatever, in the UK, any season, any make of loco:- Maxwell Hemmens - Accucraft - Roundhouse.stevedenver said:no issues with using the 70/30 propane butane mixture eh-???
Cyclone said:Cheers all and seasons greetings. Looking forward to a Santa special.
stevedenver said:tag
would the first generation SRRL from roundhouse-tank in the cab roof-be ok?
New Haven Neil 2 said:Cyclone said:Cheers all and seasons greetings. Looking forward to a Santa special.
Someone say Santa? Donk likes playing Santa Specials with his favourite loco.....
