Richie
Rio Grande Railroad , Mountain biking , Gardening
Well it's been along time coming but i promised some of you on the site that i would do a step by step guide in prunning trees . Was a nice day today so i thought i would have ago at prunning my Picea Glauca conica's which i have several of .
Step 1
Choose your tree clear the lower 6" - 8" of branches with a good pair of sharp secateurs i use Felco's to make a trunk for the tree
Step 2
Starting at the bottom of the tree hold out a branch to cut ( but before you make the cut check what the branch will look like once removed ) just remember once it's cut there's no going back if it looks ok make the cut and remove the branch do this several times thinning out as you go .
Step 3
With several branches out of the way remove all the dead inner branches this will then let the light through
Step 4
Do the same as step's 2 & 3 and work up the tree
How it should look once your finished a more open look letting light through looks more like a giant red wood
Close up of removed branches and inner dead wood
Hope this will help some of you out there fill free to add photo's of your work .
Step 1
Step 2
Step 3
Step 4
