Sarah Winfield
I hope you don't mind but I've attached another 4 photographs of my small garden. The first shows the view from my kitchen patio doors along the LHS fence. The gate at far corner opens outwards and there will be a 90 bend around that corner to run along the back fence. This 1st picture also shows, on the LHS, a temporary length of track on gravel boards on supports underneath green garden sheets.
The second picture shows the far fence of my garden with a gravel board laid over 2 wooden shelves. The idea is to have a bridge structure between the shelves. It will then go through another 90 bend to run along side the RHS shed.
The 3rd photograph shows part of the shed viewed from the end fence, with a board laid to illustrate where the track would run. The final picture show the back of the house with supports in position for taking the track at the back of the house and round to a right hand another 90 bend to continue the circuit..
The BBQ can be dispensed with and large blue plant pot can be re-sighted, even to the other side of the LHS fence
This layout gives a continuous circuit. However, there have been plans for a dumb-bell layout as an alternative.
With the supports and gravel boards the tracks are about 15" to 18" above the ground which would make rail cleaning less arduous. Laying the track at ground level has its advantages. It would extend the run under the patio doors as there is enough clearance for my Stainz.
I would welcome members thought please.
Thank you.
Sarah Winfield
Thank you.
Sarah Winfield
