Neil Robinson
I wonder if it's something to do with the motion?
Try removing all the rods from the offending bogie and retest.
kimbrit said:Hi Neil, had a good look at that, the quartering is bang on and when the motion is rotated without the motor everything has ample clearance and turns perfectly. It's definately binding somewhere but I'm damned if I can see it, I'm hoping another mallet user has experienced similar problems, the front drive unit is fine by the way and I'm wondering whether to do a swap over of gears, but if that one aint broke I'm tempted not to tamper. Keep thinking mate.
Kim
My personal preference would be to drill through the gear boss and axle and drive a roll pin in rather than use superglue. I've used this method to stop gears moving axially along the shaft.themole said:Kim, the axle of one of the three axles (rear unit) has moved on its spline/wheel.:Looser: I had this problem many moons ago there is a solution though,apply a small amount of super glue when you know the rear unit is NOT binding.
Alyn
