Rhinochugger
Retired Oik
OK - so the sale of The Earl sparks the debate about rigid chasis.
Having had some experience of building 4mm scale locos, when I built this beastie, I was prepared for the lack of side-play in scratch/kit built locos when compared with the mass market products. So I arranged for someone to turn the centre drivers to make them flangeless.
However, with hindsight, the one thing that I ought to have done is used brass for the frames, and then forced myself to use sprung horn blocks (as not in this pic)
The main issue is lack of traction. Despite a very healthy weight, and a massive 7-pole Buhler motor, there can be times when only two drivers are touching the rails (where the track lurches into sudden super elevation). As well as that, although my track laying's not the best, I expected the beast to rock occasionally on its centre drivers without electrical pickups, but being a US monster, there's plenty of pickups on the tender wheels.
So the loco goes OK, it stays on the track, and it pulls as big a train as I need.
But I built it for about £280.
But what if you pay about £900 for a factory loco?
I'm with Mel here, as someone on 'The Earl' thread has pointed out, you can buy a Bachmann Connie for £250 (list about £400) and that's an 8-coupled loco with fully sprung chassis and (now that bachmann have done all the bolts up tight) it's a lovely smooth runner, as are the K27s.
Bachmann's Annies still have plenty of axle 'slop & wobble' to even things out, which is the norm with mass manufacturers. It's probably ironic that the mass manufacturers are better at that in N gauge than they are even in 00/H0.
Not wishing to overly criticise a manufacturer that has done a huge amount for the British market, but if Accucraft are going to continue to produce hyper sensitive locos, they're not going to gain the support they need.
Caledonia had the excuse of the long wheelbase, but knowing that, Accucraft could have seen some of the difficulties coming even there.
Roundhouse have gone rigid with the Leek & Manifold 2-6-4, so while there is obviously a cost issue, for £900 for an 0-6-0, I'd expect something pretty darn good. I'd rather have a sprung chassis and less cab detail meself.
It'll be interesting to hear John (Sealion) trackshack's comments.
On the other hand, what are the USA Accucraft locos like, do they have sprung chassis?
The other part of the equation is track radius; there are a lot of G scalers who are limited to R1 & R2, and Accucraft would be crazy to ignore them.
[h5] [/h5]
[h5] [/h5]
