Anyone got any offers for good track joiners?
Fed up of the crappy LGB ones that never work electrically after a season
What track and what joiners please? I'm guessing LGB, the best fitting.
I think the logic of using those is is that one is forced to use a flat headed screw driver (yes I know you can get bits for electric ones but they tend to slip) thus ensuring that things are not too overtightened. These are made from brass and it is possible with too much force to break the screws. How do I know this? Need you ask. And yes on an electric screwdriver you could put the clutch on but you still have the issue of the bit wanting to jump out of the slot.The Massoth clamps look identical to FTW ones sold in the USA by Trainli. I’m using the nickel plated variant.
They work fine but...
Would it have killed someone to have provided Phillips head screws instead of these flat headed hellions? Or Torx/star drive...
Never bother, most of my track is ballasted with small ballast and glued. Some places I get a little bit of movement where the track is in full sun but nothing to be concerned about. This unbalasted section is known to move to the sides a bit which is why it has the bits of Hips to stop too much movement towards the drop. As you can see in full sun now for a couple of hoypurs with no sign of deflection.I assume that after clamping all the joints, you leave a good few lengths of track free to move for expansion?
