DC only, up to 24v gives you the most flexibility, but you can run lower voltages and get lower speeds.
You forgot amperage, the most important, since the smaller "starter" transformers are usually not capable of running larger locos, or 2 small ones...
If you will stay "analog" operation, buy a good one, it will last you years.
Yes, they are a lot more expensive....
