tramcar trev
Ok can I bounce this idea of the Gardeners?
I'm going to use real plants grown in pots. "Drill" (for want of a better word, with an adjustable hole cutter) holes large enough to fit the pot in through the HARDIE PLANK base and let the pot rest on the rim. The Hardie Plank is held up by timber supports and then from underneath drill a small hole in the pot and fit a dripper to it controlled by one of those lawn sprinkler controllers. Summers here are hot and dry, winters very frosty so I'm going to use some miniature Cypress as my trees. I'm going to try and "Bonsai" them in the pots...
The visible edges of the pots would have glued on stone paving to create an obvious area around the tree, a few park benches under the tree should complete the illusion when "sunk" into the fake grass. The layout just begs some foliage...
