riderdan
I posted this on the MLS site, but thought that it would be relevant here, too. The idea is for a section of "town" to have tram tracks embedded in the "street"
Here was my original idea:
My final plan was to build a "base" to glue the foam to and then put that out where the town will go as a combination street/trolley track base. I'm using foam insulation in two 1/2" layers as the base. This is kind of like the picture above, but with an extra layer to make a solid base.
The first layer is a full 8x4 sheet of foam which I will cut down as needed. The second layer has been cut out to provide a place for the track (including ties) to set down into. On top of this, I put down the black foam I got from a fellow G scaler, and cut it to just the width of the outside of the rails. The piece that came out from between the rails I cut down to leave about 1/4" on each side for the trolley wheel flanges.
The pics below give an idea of how it will look--it's been glued up and I'm waiting for the side that's weighted down to dry so I can finish it up. The gaps you can see are where the foam isn't laying flat--they should go away when everything is glued down.
Since the "middle" layer is as wide as the track (including ties) I expect any debris that gets into the gaps will fall down into the open space out of the way of the trolley wheels. I'll cut/drill a number of holes to let any accumulated water out. I'll just have to wait and see what happens with the little bit of snow and ice we get here...
The dirty spots are where some buildings were sitting on it while it was out for a test. It didn't seem to fade, it just got a bit dirty I may (or may not, depending on the effort involved) put an additional piece of gray-painted foam down on each side of the street to represent sidewalks... we'll see.
I still haven't completely figured out how I'm going to handle the wind issue (I'm in Kansas where gust of 30mph are common). I expect that with 30 pounds of buildings and track on it, it will be less of a problem. I will probably bend two pieces of steel pencil rod and drive them down into the corners on the windward side just so the wind can't get under and catch it.
(Sorry for the Imperial units, it's been 20 years since I was in the military and I've forgotten most of what I knew about metric)
