Melbournesparks
The high cost and limited availability of motor blocks in G scale is often a major barrier to scratchbuilding. Initially my trams were powered by the original Bachmann tram motor blocks, but as many people can attest they're not fantastic runners. I really needed a new drive mechanism that was a: cheap, b: ran well and c: could be made without any cutting or drilling to close tolerances. In the end a wheel and traction motor assembly just like a real one was the easiest to construct, and only costs a few dollars each.
Here is the prototype. The only 'construction' required is to solder a bit of brass tube to the outside of the motor case to hold the axle, so it is very quick and easy to build with no parts that have to be made accurately. It can be fitted to any 3mm axle, 31mm wheelset like used on most G scale rollingstock.
A set of nylon gears like this from China has enough of the right size to make one traction motor assembly, so order as many as you want powered axles.
It includes a small pinion gear for the motor, and a large spur gear with a 3mm hole to fit on the axle. Fortunately it is just the right size that when the axle is fitted into the tube on the motor case they mesh perfectly. The assembled unit could probably fit into just about any bogie, all it needs to mount it is something to hold the other side of the motor to stop it rotating.
I made a pair of traction motor and wheelset units like this for the Ballarat tram, to replace the original Bachmann motor block.
Both motors are wired permanently in series to give a realistic speed on 12v.
New 21E truck fitted in place.
Two motors is probably overkill for a tram, it will certainly pull three or four pieces of heavy rail bogie rollingstock.
Aside from a wheelset to mount it on, the only parts you need is a motor like this one:
http://www.ebay.com.au/itm/391219206218?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
A set of gears like this:
http://www.ebay.com.au/itm/221988476709?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
And a piece of 3mm inside diameter brass tube. Cost per unit is about 10 Australian dollars, not including the wheelset.
